vcRobotProgram
A standard robot program.
Module: vcRobotics2
Parent: vcProgram
Referenced by: vcRobotProgramManager.AutoStartProgram
| MainRoutine | vcRoutine | RW | Gets or sets the entry routine for the program. Only one routine can be the main at a time. |
| Variables | vcPropertyContainer | R | Gets the container of programming variables. |
| reset | None | None | " Abort the program execution and reset the program to its initial state. Parameters: None Returns: None |
| start | Boolean | None | " Starts or resumes the program execution. See moreParameters: None Returns: bool: True if program startred succesfully. False if program can't be started e.g. if it's already running. |
| stop | None | None | " Stops the current program execution. The program can be later continued by calling start(). Parameters: None Returns: None |
| OnMainRoutineChanged | None | Invoked when the MainRoutine has changed.See moreSubscribe with Callable[[vcExecutor2.vcRoutine], None]. The parameter is the new main routine or None. |
